Most Online Today: 1
Author Topic: Renewable Hydrogen Power  (Read 630 times)
Re: Renewable Hydrogen Power
« on: June 19, 2016, 07:42:16 pm »
clean hydrogen and rechargable zinc batteries
June 17, 2016
Stanford researchers find new ways to make clean hydrogen and rechargable zinc batteries
Stanford engineers created arrays of silicon nanocones to trap sunlight and improve the performance of solar cells made of bismuth vanadate (1μm=1,000 nanometers). Credit: Wei Chen and Yongcai Qiu, Stanford
A Stanford University research lab has developed new technologies to tackle two of the world's biggest energy challenges - clean fuel for transportation and grid-scale energy storage.
The researchers described their findings in two studies published this month in the journals Science Advances and Nature Communications.
Hydrogen fuel
Hydrogen fuel has long been touted as a clean alternative to gasoline. Automakers began offering hydrogen-powered cars to American consumers last year, but only a handful have sold, mainly because hydrogen refueling stations are few and far between.
"Millions of cars could be powered by clean hydrogen fuel if it were cheap and widely available," said Yi Cui, an associate professor of materials science and engineering at Stanford.
Unlike gasoline-powered vehicles, which emit carbon dioxide (CO2), hydrogen cars themselves are emissions free. Making hydrogen fuel, however, is not emission free: today, making most hydrogen fuel involves natural gas in a process that releases CO2 into the atmosphere. *
To address the problem, Cui and his colleagues have focused on photovoltaic water splitting. This emerging technology consists of a solar-powered electrode immersed in water. When sunlight hits the electrode, it generates an electric current that splits the water into its constituent parts, hydrogen and oxygen.
Finding an affordable way to produce clean hydrogen from water has been a challenge. Conventional solar electrodes made of silicon quickly corrode when exposed to oxygen, a key byproduct of water splitting. Several research teams have reduced corrosion by coating the silicon with iridium and other precious metals.
Writing in the June 17 edition of Science Advances, Cui and his colleagues presented a new approach using bismuth vanadate, an inexpensive compound that absorbs sunlight and generates modest amounts of electricity.
"Bismuth vanadate has been widely regarded as a promising material for photoelectrochemical water splitting, in part because of its low cost and high stability against corrosion," said Cui, an associate professor of photon science at the SLAC National Accelerator Laboratory. "However, the performance of this material remains well below its theoretical solar-to-hydrogen conversion efficiency."
Bismuth vanadate absorbs light but is a poor conductor of electricity. To carry a current, a solar cell made of bismuth vanadate must be sliced very thin, 200 nanometers or less, making it virtually transparent. As a result, visible light that could be used to generate electricity simply passes through the cell.
To capture sunlight before it escapes, Cui's team turned to nanotechnology. The researchers created microscopic arrays containing thousands of silicon nanocones, each about 600 nanometers tall.
Left (a): A conventional zinc (Zn) battery short circuits when dendrites growing on the zinc anode make contact with the metal cathode. Right (b): Stanford scientists redesigned the battery using plastic and carbon insulators to prevent zinc dendrites from reaching the cathode. Credit: Shougo Higashi
"Nanocone structures have shown a promising light-trapping capability over a broad range of wavelengths," Cui explained. "Each cone is optimally shaped to capture sunlight that would otherwise pass through the thin solar cell."
In the experiment, Cui and his colleagues deposited the nanocone arrays on a thin film of bismuth vanadate. Both layers were then placed on a solar cell made of perovskite, another promising photovoltaic material.
When submerged, the three-layer tandem device immediately began splitting water at a solar-to-hydrogen conversion efficiency of 6.2 percent, already matching the theoretical maximum rate for a bismuth vanadate cell.
"The tandem solar cell continued generating hydrogen for more than 10 hours, an indication of good stability," said Cui, a principal investigator at the Stanford Institute for Materials and Energy Sciences. "Although the efficiency we demonstrated was only 6.2 percent, our tandem device has room for significant improvement in the future."
Rechargeable zinc battery
In a second study published in the June 6 edition of Nature Communications, Cui and Shougo Higashi, a visiting scientist from Toyota Central R&D Labs Inc., proposed a new battery design that could help solve the problem of grid-scale energy storage.
"Solar and wind farms should be able to provide around-the-clock energy for the electric grid, even when there's no sunlight or wind," Cui said. "That will require inexpensive batteries and other low-cost technologies big enough to store surplus clean energy for use on demand."
In the study, Cui, Higashi and their co-workers designed a novel battery with electrodes made of zinc and nickel, inexpensive metals with the potential for grid-scale storage.
A variety of zinc-metal batteries are available commercially, but few are rechargeable, because of tiny fibers called dendrites that form on the zinc electrode during charging. Theses dendrites can grow until they finally reach the nickel electrode, causing the battery to short circuit and fail.
The research team solved the dendrite problem by simply redesigning the battery. Instead of having the zinc and nickel electrodes face one another, as in a conventional battery, the researchers separated them with a plastic insulator and wrapped a carbon insulator around the edges of the zinc electrode.
"With our design, zinc ions are reduced and deposited on the exposed back surface of the zinc electrode during charging," said Higashi, lead author of the study. "Therefore, even if zinc dendrites form, they will grow away from the nickel electrode and will not short the battery."
To demonstrate stability, the researchers successfully charged and discharged the battery more than 800 times without shorting.
"Our design is very simple and could be applied to a wide range of metal batteries," Cui said.
Explore further: Researchers create a low-cost, long-lasting water splitter made of silicon and nickel
More information: Efficient solar-driven water splitting by nanocone BiVO4-perovskite tandem cells, Science Advances, DOI: 10.1126/sciadv.1501764
Journal reference: Science Advances search and more info website Nature Communications search and more info website
Provided by: Stanford University search and more info website
http://phys.org/news/2016-06-ways-hydrogen-rechargable-zinc-batteries.html
* This is known as Steam Forming and has a NEGATIVE ERoEI. It is stupid but fossil fuel industry subsidies make it "cost effective", just like the insanely stupid negative ERoEI activity of making about 5% of the world's Ethanol using fossil fuel feed stock.
I applaud the new technology discussed in the above article.  But expect the fossil fuel industry to make their typical claim that "it's a great idea, but not ready for prime time  " as an excuse to continue to justify the polluting gasoline powered status quo as a "necessary" evil (when they aren't touting it as the savior of humanity, that is).
The fact is that Hydrogen fuel for vehicles has been ready for prime time for over 50 YEARS.    Mormon farmers have been running their tractors on it for at least that long.
While it is true that storing hydrogen, AS A GAS, is tough and energy intensive, "storing" it as WATER, to be used when you need it for a few hours from a solar powered electrolyzer, is old hat, as long as the sun comes out that day. ;D
It's BULLSHIT to claim well insulated low temperature hydrogen fuel tanks could not have been mass produced and economically iincorporated into our vehicles by a country that pioneered the technology for ICBMS, hydrogen bombs and the space shuttle.
And furthermore, if the nukers had allowed a certain isotope of hydrogen to be used to produce a hydride that could economically store hydrogen gas (at room temperature with zero leakage) in SCUBA tank like bottles in a vehicle, we could all be running hydrogen collected from a home solar powered electrolyzer in our cars. A catalytic agent releases the gas from the hydride gradually as needed to run your engine. And, by the way, your risk of explosion and fire with this system is far lower than with a gasoline tank.
It didn't happen because all those terrorists among us would run out and make hydrogen bombs from heavy water...  Fossil fuel industry fuel product profits from 42% PLUS of their refinery CRAP had, and has, nothing whatsoever to do with it.  LOL!
