Total Members: 54
Latest: abrogard
Total Topics: 270
Most Online Today: 4
Most Online Ever: 1155
(April 20, 2021, 12:50:06 pm)
Guests: 3
Total: 3
Author Topic: Masdar Engage Contest Entry by A. G. Gelbert  (Read 788 times)
Egypt has developed a game-changing low-power water desalination technique
About 71 percent of the Earth’s surface is covered by water, but unfortunately most of that liquid nourishment isn’t suitable for drinking because it’s salt water found in the oceans. Removing salt from water is not an easy process, either. Current desalination technology requires a high amount of energy, making it prohibitively expensive — especially in developing nations. But don’t worry: a team of researchers at Alexandria University in Egypt have bypassed these power-hungry methods and created a simple filtration technique; the details of which are described in a research paper published last month in Water Science and Technology.
To remove salt from water with minimal power, the researchers use the process of pervaporation, in which salt water is first filtered though a membrane to remove larger particles.
These filters contain cellulose acetate powder that, along with other components, will bind the salt particles as they pass through the membrane. Made from materials common to Egypt and surrounding countries, the filters are affordable and can easily be produced in a laboratory setting.
Related: Hawaii’s new OTEC power plant harvests energy stored in warm ocean water
Once filtered, the water is vaporized under heat in a second purification step. The vapor, containing pure water, is then condensed and collected for drinking purposes. This method reportedly works with sea water, even the highly-salinized water of the Red Sea. It also purifies water that’s been contaminated with sewage and/or dirt, which makes it beneficial for use in developing nations. Because it uses ingredients available locally and does not require lot of energy, desalination via pervaporation is a relatively inexpensive process. “Using pervaporation eliminates the need for electricity that is used in classic desalination processes, thus cutting costs significantly,” says said Ahmed El-Shafei, an associate professor of agricultural and biosystems engineering in Alexandria University.
The method of pervaporation has been in use since the early 1990s and is being used in waste water treatment to separate organic solvents from industrial waste water. The team hopes to scale up production of the saline-removine membrane, printing it off in sheets that can be cut down for individual use. It also is working on a pilot desalination unit to test out the method on a larger scale.
http://finance.yahoo.com/news/egypt-developed-game-changing-low-211511213.html
« Last Edit: September 08, 2021, 02:46:14 pm by AGelbert »
Light is sown for the righteous, and gladness for the upright in heart. Ps. 97:11
Pollution by AGelbert
September 20, 2021, 06:19:29 pm
Fossil Fuel Propaganda Modus Operandi by AGelbert
September 20, 2021, 05:47:46 pm
September 19, 2021, 05:59:25 pm
September 18, 2021, 02:17:10 pm
Corporate Profits over Patient in the Health Care Field by AGelbert
September 18, 2021, 01:57:52 pm
September 16, 2021, 01:17:05 pm
🎋 Victories Against the 🦕 Hydrocarbon Hellspawn by AGelbert
September 16, 2021, 01:16:43 pm
September 15, 2021, 01:00:09 pm
September 14, 2021, 02:36:15 pm
September 13, 2021, 01:39:49 pm
