Total Topics: 268
Most Online Today: 16
Guests: 2
Total: 2
Author Topic: Batteries  (Read 8317 times)
Re: Batteries
« Reply #75 on: February 08, 2018, 12:20:17 pm »
Compound Could Transform Energy Storage ⚡ for Large Grids
February 7, 2018
By Bob Marcotte
energy storage
Ellen Matson, left, assistant professor of chemistry, and PhD student Lauren VanGelder at work in Matson's lab. VanGelder is lead author on a paper describing modifications to a redox flow battery that make it nearly twice as effective for electrochemical energy storage. Credit: University of Rochester | Matson Lab
In order to power entire communities with clean energy, such as solar and wind power, a reliable backup storage system is needed to provide energy when the sun isn’t shining and the wind doesn’t blow.
One possibility is to use any excess solar- and wind-based energy to charge solutions of chemicals that can subsequently be stored for use when sunshine and wind are scarce. At that time, the chemical solutions of opposite charge can be pumped across solid electrodes, thus creating an electron exchange that provides power to the electrical grid.
The key to this technology, called a redox flow battery , is finding chemicals that can not only “carry” sufficient charge, but also be stored without degrading for long periods, thereby maximizing power generation and minimizing the costs of replenishing the system.
University of Rochester researchers, working with colleagues at the University at Buffalo, believe they have found a promising compound that could transform the energy storage landscape.
In a paper published in Chemical Science, an open access journal of the Royal Society of Chemistry, researchers in the lab of Ellen Matson, assistant professor of chemistry, describe modifying a metal-oxide cluster, which has promising electroactive properties, so that it is nearly twice as effective as the unmodified cluster for electrochemical energy storage in a redox flow battery.
“Energy storage applications with polyoxometalates are pretty rare in the literature,” says lead author Lauren VanGelder, a third-year PhD student in Matson’s lab. “There are maybe one or two examples prior to ours, and they didn’t really maximize the potential of these systems.”
“This is really an untapped area of molecular development 💫,” adds Matson.
A redox flow battery uses excess solar- and wind-based energy to charge solutions of chemicals that can subsequently be stored for use when sunshine and wind are scarce. At that time, the chemical solutions of opposite charge can be pumped across solid electrodes, thus creating an electron exchange that provides power to the electrical grid. Credit: University of Rochester | Michael Osadciw
The cluster was first developed in the lab of German chemist Johann Spandl, and studied for its magnetic properties. Tests conducted by VanGelder showed that the compound could store charge in a redox flow battery, “but was not as stable as we had hoped.”
However, by making what Matson describes as “a simple molecular modification”— replacing the compound’s methanol-derived methoxide groups with ethanol-based ethoxide ligands—the team was able to expand the potential window during which the cluster was stable, doubling the amount of electrical energy that could be stored in the battery.
Says Matson: “What’s really cool about this work is the way we can generate the ethoxide and methoxide clusters by using methanol and ethanol. Both of these reagents are inexpensive, readily available and safe to use. The metal and oxygen atoms that compose the remainder of the cluster are earth-abundant elements. The straightforward, efficient synthesis of this system is a totally new direction in charge-carrier development that, we believe, will set a new standard in the field.”
The electrochemical testing required for this study involved equipment and techniques not previously used in the Matson lab. Hence the collaboration with Timothy Cook, assistant professor of chemistry at the University of Buffalo, and Anjula Kosswattaarachchi, a fourth-year graduate student in the Cook lab. VanGelder visited the Cook lab for training on testing equipment, and in turn helped Kosswattaarachchi with synthesizing compounds.
The two groups have applied for a National Science Foundation grant as part of an ongoing collaboration to further refine the clusters for use in commercial redox flow batteries.
Matson stressed the “crucial role” played by VanGelder, who conducted the initial testing and experiments on the clusters while Matson was on maternity leave. “As a third-year graduate student, she did an incredible job of starting this project. She’s played an important role in driving this research effort in the lab,” Matson says.
A University Furth Fund Award that Matson received last year enabled the lab to purchase electrochemical equipment needed for the study. Patrick Forrestal ’19 of the Matson lab also contributed to the study.
http://www.renewableenergyworld.com/articles/2018/02/compound-could-transform-energy-storage-for-large-grids.html
A Journal of the Plague by AGelbert
06 Apr, 2020 23:58
06 Apr, 2020 22:50
06 Apr, 2020 21:11
06 Apr, 2020 21:03
911 > September 11 2001 > U.S. Fascist COUP? by AGelbert
06 Apr, 2020 19:06
New Pandemic? by AGelbert
06 Apr, 2020 17:14
06 Apr, 2020 07:02
Mechanisms of Prejudice: Hidden and Not Hidden by AGelbert
06 Apr, 2020 00:14
Viruses of the Mind by AGelbert
05 Apr, 2020 22:02
Darwin by AGelbert
05 Apr, 2020 16:05
