What Is A Solid-State Battery and Will They Solve Our Battery Life Problems?
MICHAEL CRIDER @michaelcrider
NOVEMBER 9, 2018, 6:40AM EDT
Solid-state batteries promise a few distinct advantages over their liquid-filled cousins: better battery life, faster charging times, and a safer experience.
Solid-state batteries compress the anode, cathode, and electrolyte into three flat layers instead of suspending the electrodes in a liquid electrolyte. That means you can make them smaller—or at least, flatter—while holding as much energy as a larger liquid-based battery. So, if you replaced the lithium-ion or lithium-polymer battery in your phone or laptop with a solid-state battery the same size, it would get a much longer charge. Alternatively, you can make a device that holds the same charge much smaller or thinner.
Solid-state batteries are also safer, since there’s no toxic, flammable liquid to spill, and they don’t output as much heat as conventional rechargeable batteries. When applied to batteries that power current electronics or even electric cars, they might recharge much faster, too—ions could move much more quickly from the cathode to the anode.
According to the latest research, a solid-state battery could outperform conventional rechargeable batteries by 500% or more in terms of capacity, and charge ⚡ up in a tenth of the time. 👍
Read more: https://www.howtogeek.com/393503/what-is-a-solid-state-battery-and-will-they-solve-our-battery-life-problems/
