EV vs ICE Maintenance – The First 100,000 miles
2 years ago by Mark Hovis ( Don't forget EV prices have gone down since then!)
If you drive an ICE (Internal Combustion Engine) and have a service file, take it out for comparison. If you own an ICE and don’t have a service file, you should start one,
for you will be shocked with how much time and effort you really spend on your vehicle. You may find the service costs found here higher or lower. They are listed as a reminder of how often you require service. The more expensive your auto, the more the manufacturer or dealer pads the service charges. Still, you have to endure these regular maintenance issues.
TiresTires are the common denominator between both types of vehicles. The recommended rotation is every 7500 miles. Hence you will have 13 scheduled trips to your mechanic in the first 100,000
Check the fluids!Oil change ICE: The frequency of oil changes vary from person to person and manufacturer. The number used to be 3000 miles. If you change every 5000, that will be 20 scheduled visits out of your daily routine and about $400-$800.
EV:
No thanks! Automatic transmission fluidICE: This is generally recommended to be changed at 100,000. Depending on whether you flush the system and change the filter or just add fluid, you will spend between $30-$100
EV:
No thanks! :
CoolantICE: Generally this will last for 150,000 before recommended change, but you DO have to keep a check on it throughout the life of the ICE for you can do considerable engine damage if you let it run hot.
EV:
If you have a thermal management system on your battery, you will have a similar check.Fuel400 visits isn't that bad ICE: The frequency with which a person fills their ICE varies. The norm is generally once per week. If this is your pattern, and you are driving the national average of 12,750 miles per year, then you have invested FOUR HUNDRED TRIPS to the gas station in your first 100,000 miles. For the lucky, the trip is on their normal route, for others, four hundred special trips. I call that heavy maintenance! 100,000 miles @ $3.50/gal and avg of 28 miles/gal costs $12,500. Calculate your own
EV:
You have plugged and unplugged daily for eight years normally taking 3-5 seconds. The difference being 90 percent are done at the convenience of your home, not investing in an additional four hundred visits to the pump. Average cost 3.5 cents/mile $3500. Check out what EV drivers say about this. :icon_mrgreen:
Spark Plugs and wiresICE: Generally recommended in the first 100,000. Cost DIY $60 Shop $200.
EV:
No thanks! Muffler(
and a tail pipe)
ICE: Location and driving distance are just a few issues that will determine the life of your muffler. Short distances do not give time for condensation to dry out thus shortening the life unless it is stainless steel. It is also a high probability that you have to replace more than just the muffler. Generally $100-$250
EV:
No thanks! BrakesICE: Depending on your vehicle and driving style, you will probably have at least 2 trips to your mechanic in the first 100,000. Will budget $200 per visit so call it $400
EV: The regenerative brakes will cut your visits to the mechanic in half. Still we will plan on one visit in the first 100,000. Costs $200
The big 100,000 mile maintenanceKa-Ching!
ICE: Timing belts are recommended every 60,000-100,000 with most ICEs not equipped with timing chains. In fact, most recommend that you go ahead and replace the water pump while you are at it. Most service centers will charge for the pump only since the labor is already invested in the timing belt. Cost $600- $800 for the timing belt only. $900- $1100 for both.
Other possible expenses that the ICE can encounter in the first 100,000 include a catalytic converter and automatic transmission as some of the more expensive possibilities.
Leaf Battery replacement
Refurbished 23kWh battery for $5500 EV: The big “potential” cost is the battery replacement. At 100,000 miles, your battery may have lost up to 20% of its range, though studies from the American Chemical society predict well managed batteries may last up to twenty years. Unlike the timing belt, you are not running the risk of damaging your vehicle by continuing to drive, so many may continue to drive without this expense. The initial cost in 2012 was around $500-$600/kWh. Studies show this cost could drop to $150-$250/kWh in the next 5-8 years which happens to be the warranty period for most EV battery systems. Already 2013 is showing some packs at 400/kWh.
Some batteries are designed in such a manner as to replace modules opposed to the entire pack which will generally be the better OEM solution. This has allowed some 24kWh OEM refurbished packs to be offered for $5500 or $240/kWh with a core charge. Parity has arrived.
Ease of installation also matters. GM and Nissan are able to offer low labor rates due to their easy access. You should be aware of the installation labor cost before making a purchase. This price is based on the design, not the future cost of the battery.
It is still too early to realize the aftermarket pricing but this is sure to follow. With a large number of early adopters also investing in solar, it is likely that they may keep their old battery as a future solar home battery back up if core values are too small.
Also for the EV with a renewed battery solution, you effectively have hit the reset button for the next 100,000. Not the case for the ICE. The mechanical components of the ICE continue to wear and are now subject to the same continual maintenance as well as at least one major service call on the way to 200,000 miles. But this is not the largest looming cost. At this point, we are 10-15 years into rising gas and lowering battery cost . By this time, rising gas and lowering battery costs, have almost certainly made the ICE a relic on the road to 200,000 miles.
Now you might think that I am implying that the EV is unbreakable. This obviously with anything mechanical is not the case.
I am first and foremost pointing out the huge imbalance in regular maintenance. I made mention of possible failures with the ICE like the automatic transmission.
I challenge you once again to review your own ICE service file to better understand the extra cost you may have been trying to forget.
You will have similar possibilities with the EV with anything in the electrical system from inverters to rectifiers.
One major difference being that in most good EV warranties, the electrical system is covered for the first 100,000 miles, which is the emphasis of this piece. So if you are considering your first EV, make sure to ask for a specific breakdown of what is covered in their warranty. Though nothing is maintenance free,
I think you will find a huge imbalance in favor of the EV.
http://insideevs.com/ev-vs-ice-maintenance-the-first-100000-miles/RE,
You may claim the above is "just" maintenance and has NOTHING TO DO with energy required to move the vehicle. Oh yes it DOES! Maintenance USES ENERGY! A lot of it!. 400 trips to the gas station are part of your ICE DUTIES, are they not? That uses ENERGY, does it not?
And so on.
