Total Members: 54
Latest: abrogard
Total Topics: 274
Most Online Today: 10
Most Online Ever: 1155
(April 20, 2021, 12:50:06 pm)
Author Topic: Electric Vehicles  (Read 32015 times)
Catchy title! But it's mostly true!
« Reply #645 on: September 24, 2021, 02:08:10 pm »
1,320,354 views Sep 23, 2020
Electric carchargers aren't chargers at all – EVSE Explained 🧐
Technology Connections   1.37M subscribers
Catchy title! But it's mostly true! There's a pinned comment you might want to read, as well. But there's some links down here, too.
Pinned by WeberAuto
Keith McDonnell
A quick correction for you, the battery heater does function when CCS charging in cold conditions.  The complaint is that charge rate is reduced when the battery pack is cold, and the heater is only 2 KW.  The problem is that the battery heater shuts off around 64F pack temperature, and at that point maximum charge amps is still limited to less than 110 amps.  This may seem like a lot, but the Bolt max charging amps with a warm battery is 150 amps.  I think the logic was that when they set up the programming for the system, most publicly available CCS chargers maxed out at 100 amps, with a few 125 amp stations.  Now with lots of 125 amp stations and 150+ amp stations becoming available they need to reprogram the battery heater to vary it's shut off point based  on power available, so it stays on to a much higher pack temperature when connected to a higher power CCS station to maximize charging rate.
Firstly and of supreme importance, the video on the Bolt's Bits from Weber Auto - Prof. John Kelly is amazing and you really ought to give that channel a look if you're interested at all in hybrid and ⚡ EV tech;
Light is sown for the righteous, and gladness for the upright in heart. Ps. 97:11
Fossil Fuel Subsidies - The Invisible Ones are Worse Than the Obvious Ones! by AGelbert
December 05, 2021, 09:32:10 pm
December 05, 2021, 03:12:46 pm
December 05, 2021, 02:29:48 pm
December 04, 2021, 07:12:26 pm
Non-routine News by AGelbert
December 04, 2021, 01:01:27 pm
Fossil Fuel Propaganda Modus Operandi by AGelbert
December 03, 2021, 03:24:18 pm
Christian Teachings by AGelbert
December 03, 2021, 12:36:29 pm
December 01, 2021, 05:40:52 pm
Doomstead Diner by AGelbert
November 30, 2021, 05:02:02 pm
Earthquakes by AGelbert
November 29, 2021, 06:31:37 pm
