THE REPORTDesigners vs. Climate Change
Leading architects, designers, and urban planners are devising plans to help mitigate greenhouse gas emissions. Are they our best hope for a brighter future?Posted July 4, 2018
text by Meaghan O'Neill
For professionals like these, business as usual is simply outdated. In the U.S. today, buildings consume 39 percent of total energy used—higher than both the transportation (29 percent) and industrial (32 percent) sectors. But what if buildings—or even entire cities—could generate more energy than they used, clean the surrounding air and water, and even sequester carbon dioxide?
The idea isn’t too far-fetched.Technology to mitigate emissions already exists, is accessible, and can even be cost-effective. And small course corrections in our approach to the built environment could make a big a difference in emissions industry-wide. (Designing for resilience—that is, creating and protecting built environments that will withstand rising seas, more frequent and severe storms, and other effects of climate change—is also paramount.)
According to Paul Hawken’s 2017 book Drawdown, if just 9.7 percent of new buildings were net-zero energy by 2050, global greenhouse gas emissions would be 7.1 gigatons lower. That’s equivalent to eliminating annual emissions from all livestock worldwide. Yet the biggest barrier to building greener buildings and cities may not be cost or political will, but simply inertia.
Top: A modern home by ZeroEnergy Design; Above: The interior of a barn renovated by ZeroEnergy Design. Photo: Eric Roth
“Designing a building to code is the worst possible building you could build,” says Horowitz.
“We need to do better.” Considering fuel inputs, the entire lifecycle of a building and the future of the grid are essential factors, says Horowitz, a self-proclaimed “data literacy” advocate who joined the Architecture 2030 Challenge (a group with the goal to make all buildings and major renovations carbon-neutral by 2030) as a way to stay publicly accountable for all projects in her portfolio.
It’s also worth mentioning that building smaller, more efficient spaces would go a long way toward reducing our collective carbon footprint. In the 1950s, for example, the size of the average American home was about 1,700 square feet; today, it’s
closer to 2,500 🐷 🐖.
Designing for Low Carbon Impact—and Human Beings
“Decisions we make as architects and engineers impact the land we build on for the next 100 years,” says Cara Carmichael, an engineer and environmental designer at the Rocky Mountain Institute, a nonprofit organization that works to dissuade the use of fossil fuels. With the help of ZGF Architects, RMI recently built its 15,610-square-foot Innovation Center in Basalt, Colorado, to be a showcase of net-zero energy efficiency.
By using high-end windows and insulation, an airtight envelope, passive solar design, natural and efficient artificial lighting, automation and metering, natural ventilation, and photovoltaics, the building can produce more energy than it uses in a year. In cooler months, radiant heating delivers warm air where people need it most, instead of overheating low-use spaces (like ceilings and transitional areas). The result is a building that’s 74 percent more efficient than its average counterpart.
While advanced systems react to external weather and lighting conditions, people who occupy the building retain precise control over their micro-environments. Desk, ceiling, and even in-chair fans allow for personal adjustments. And while a sophisticated louver system creates shade as necessary—eliminating the need for air conditioning—individuals can open windows when they want fresh air. Because buildings like this champion low-tech methods (tight envelopes and LED lighting, for example) rather than high-tech mechanical systems, they can often be built at or near the same cost as a traditional building.
One key to success is the early integration of cross-disciplinary teams who can accurately predict how a building will perform over its lifecycle. “It’s not just a check-the-box thing,” says Carmichael, who collaborated with architects, engineers, land planners, solar and lighting experts, and contractors to crunch numbers from the get-go. “It’s a powerful tool to shape design.”
Net Zero, Passive House, and Living Buildings
Since the 1990s, various certifications, like the U.S. Green Building Council’s Leadership in Energy and Environmental Design, have emerged for healthier buildings with lower carbon impact. Now, Net Zero, Passive House, and Living Buildings labels are also helping designers create better spaces. Though specific criteria vary, they ultimately share several common goals: The design of built environments that use less fossil fuel energy, produce less pollution, and improve the well-being of people who use them.
Built in collaboration with the Miller Hull Partnership, the Bullitt Center in Seattle, a designated Living Building, is a net-positive energy building that uses photovoltaics to generate power. There’s no cooling system—windows automatically open and close—and it even employs six stories of composting toilets. In short, it operates like a natural system—always responding to its conditions.
Designer Jason McLennan explains Living Buildings in a TEDx talk.
To reduce their impacts significantly, such buildings implement these and other tools, including ground source heat pumps, smart thermostats, green roofs, and closed-loop water systems. While some features remain expensive to install, all are easy to acquire.
Several public and multi-unit Passive House projects are also pushing the efficiency envelope. In New York,
the Perch Harlem, designed by architect Chris Benedict,
consumes 90 percent less energy than a standard building and 75 percent less than similar new construction. “Making these projects happen—and quickly—at scale is really exciting,” says Horowitz, who has also worked on several multi-unit spaces. Elsewhere, entire communities are working toward net-zero energy goals. In Cambridge, Massachusetts, for example, plans are underway for all new buildings to be net-zero by 2040.
FULL ARTICLE: https://www.architecturaldigest.com/story/designers-architects-take-on-climate-change
