Total Topics: 267
Most Online Today: 54
Guests: 4
Total: 4
Author Topic: A High-Renewables Tomorrow, Today:  (Read 5340 times)
Re: A High-Renewables Tomorrow, Today:
« Reply #60 on: August 29, 2017, 02:56:59 pm »
Hybrid Office Building Cuts Cord to Electricity Grid
August 29, 2017
By Andrew Spence, The Lead
 hybrid energy
A four-story office building powered by a combination of thermal and PV solar and wind energy in South Australia has cut its connection to the electricity grid in what its owners claim to be a world first.
The $8 million Fluid Solar headquarters in Adelaide, South Australia’s northern suburbs contains more than 2 MWh of energy storage capacity, comprising about 90 percent thermal storage with the remaining 10 percent provided by conventional battery storage.
Fluid Solar House has been operating without the use of the electricity grid since April to test its technologies before this afternoon’s cord-cutting ceremony.
The building will be used as the small company’s headquarters but will also become a co-working space for other innovative northern suburbs’ startups.
Surplus electricity generated at the site will be used as part of Tesla’s car-charging network, with provision of 11 electric vehicle bays that will be charged completely by wind and solar power harvested from a 98 kWp array of 378 PV solar panels on the building’s roof.
A sustainable “tiny house” has also been built — in just three days — in the building’s car park to showcase the company’s low cost, low energy accommodation.
Fluid Solar Managing Director Roger Davies has been working on the technology since 2008 and said the solar thermal element was the key to the building’s success.
He said solar PV cells alone typically could not produce enough energy to run an air conditioning system.
“Even if you could, the cost of the battery pack becomes so large that it’s difficult to pay the battery pack off before it wears out,” he said.
“Storage of heat is dramatically cheaper than battery storage and because we’ve got the other end, which is the devices that use thermal energy directly for their heating and cooling it means that 60-70 per cent of the building’s energy requirements are met using solar thermal as opposed to solar PV technology.
“That allows us to use the rest of the roof — about 60 percent — to do a conventional PV.
So we have a hybrid model between a smaller battery pack running the lights, the lift, the fan systems and so on and the heavy lifting is done by the solar thermal.
Wind turbines on the roof are also in place to fill the void for about 20 days in winter when long stretches of cloudy weather reduce the effectiveness of solar. The surplus electricity will be used to power the car charging station.
The solar thermal collectors have been granted an Australian patent, and we’re in the process of getting an international patent in several jurisdictions including China, India, Japan, North America and Europe.
They work by heating rainwater collected at the site to between 60C and 90C and storing it in a 10,000-liter insulated box. The hot water can be used to directly heat the building in winter and indirectly in summer to dry air and run evaporative cooling.
The building also has a turbine that turns low pressure steam into electricity.
“If you collect solar energy as heat, you store it as heat and you use it as heat, the whole process is intrinsically efficient and cost-effective and that is the trick to moving to a much lower energy consumption society, Davies said.
The company is working on a system that can be retrofitted to existing office buildings.
“That’s certainly feasible from a technical point of view and once clients accept that it’s also economically attractive to them we see no reason why that technology couldn’t be rolled out across a large percentage of existing buildings.”
Fluid Solar has a 1200sq m factory in the nearby industrial suburb of Edinburgh. It has 24 orders for small houses, which range in size from 40sq m to 160sq m.
The houses are powered by similar renewable energy systems as the office building, can be run off-grid and can be built on site in a matter of days.
“Our order book is probably filled till Christmas but we’re certainly looking to have some projects moving into 2018 to keep the momentum going and build production,” Davies said.
“We’ve looked at 5000sq m as our next step up when demand picks up. I’ve got a joint arrangement with an existing manufacturing business to gear up and help build large volume if we can show the demand.”
Davies said the small modulated houses had a number of markets including as backyard flats, off-grid holiday homes and housing for people on fixed incomes.
He said the fast build times, low or no ongoing electricity costs and a price of about AU$1,000 per square meter compared with $1,200 – $1800sq m for traditional housing made them very affordable.
Fluid Solar has approval to build a 20-apartment complex in Munno Para, which Davies hopes to have installed before Christmas.
“One thing I would very much like to do is build these as medium density urban and suburban housing because we believe we can get the cost down to a point where people on low fixed incomes can afford to rent or buy over time,” he said.
“My belief is that our strategy of using a building that is intrinsically low energy consuming will ultimately become the dominant feature in architecture — we will move away from poorly insulated, glazed energy hot boxes and people will start to accept that the advantages of low consumption and low impact living are more important.”
South Australia leads the nation in the uptake of wind energy and roof-top solar with renewable sources accounting for more than 40 percent of the electricity generated in the state. However, the closure of two coal-fired power stations in recent years has increased South Australia’s reliance on energy supplies from the eastern Australian states, particularly in times of peak demand.
Last month, tech billionaire Elon Musk announced his company Tesla would install the world’s biggest lithium-ion battery at a wind farm in South Australia. This month, SolarReserve announced it would construct a 150MW solar thermal power plant in the state’s north.
This article was originally published by The Lead South Australia under a creative commons license.
http://www.renewableenergyworld.com/articles/2017/08/hybrid-office-building-cuts-cord-to-electricity-grid.html
Agelbert NOTE: The above is admirable, but it is also common sense. I wish to bring your attention to the possibility, which I consider a fact, that the encouragement given the populace over the last century or so to use energy without absolutely any consideration for efficiency has been deliberate by the fossil fuel industry.
WHY? Because the more fossil fuels we burned, the more money they made. All that ubiquitous ego inflating advertizing about "freedom" and "independence" and "doing it your way" energy use bling was a clever appeal to human greed and "do BETTER than the Joneses" base human psychology.
They convinced an entire generation that the advantages of low consumption and low impact living is something to be scorned, despite the biosphere math FACT that low consumption and low impact living is the ideal all humans should strive to achieve in order to preserve and protect the environment for their children.
IOW, through clever ego inflating ubiquitous advertising propaganda, they made greedy suckers out of most of us.
At the same time, the mendacious crooks that push polluting energy sources claimed, and still claim, that they would be happy to incorporate 'efficiency increases' to reduce fossil lfuel use and would 'support' Renewable Energy sources too.   But alas, the fossil fuel product is the most "cost effective" and "competitive" product out there.
This was a half truth at best. The petroleum pigs certainly do go all out to make oil and gas extraction machinery as efficient as possible to increase profits. But they are totally against more efficency at the consumer level. They are the ones responsible for the minimum furnace size requirements in all buildings and many other code requiring INEFFICIENCIES that guarantee MORE fossil fuel use. And that's just the tip of the mens rea fossil fuel industry turdberg out there.
So, when the FACT that intrinsically low energy consuming architecture has been vigorously shunned by the fossil fuel industry for over a century is exposed, the malice and forethought on their part in encouraging totally unnecessary and massively inefficient high energy use becomes clear.
They WANT us to use a lot of energy so they can turn around and say our "standard of living", if not our very lives, will suffer "grievous harm" without fossil fuels.
Amory Lovins of the Rocky Mountain Institute wrote a peer reviewed scientifc paper (Reinventing Fire) making it crystal clear that we can run human civilization on 80% LESS energy than we now use by incorporating various transportation, machinery, building and housing energy efficiency increasing technologies along with Renewable Energy WITHOUT ANY lowering of our standard of living.
So when you hear a fossil fueler claim that intrinsically low energy consuming architecture 'isn't competitive or cost efficient' (i.e. not ready for 'prime time'  ;)) along with their standard crocodile tears about how our "standard of living will suffer grievous harm" (i.e. 'we are all gonna die without our loyal servant the Fossil Fuel Industry') without fossil fuels, please show them the following meter reading in regard to everything they said:
The Fossil Fuelers DID THE Clean Energy  Inventions suppressing, Climate Trashing, human health depleting CRIME,   but since they have ALWAYS BEEN liars and conscience free crooks, they are trying to AVOID   DOING THE TIME or     PAYING THE FINE!     Don't let them get away with it! Pass it on!
April 03, 2020, 04:15:47 pm
April 03, 2020, 02:36:44 pm
New Pandemic? by AGelbert
April 03, 2020, 01:30:26 pm
April 03, 2020, 12:19:45 pm
April 03, 2020, 12:08:55 pm
April 03, 2020, 07:53:58 am
Darwin by AGelbert
April 02, 2020, 11:47:08 pm
Comic Relief by AGelbert
April 02, 2020, 11:12:44 pm
April 02, 2020, 10:25:42 pm
April 01, 2020, 11:13:13 pm
